Federico Coto F... Fri, 10/01/2010 - 11:12
The PIX-515 can run 8.0(4) however requires a minimum of 16 MB Flash and 64 MB RAM.
Check if that's the problem with the command ''sh ver''
Federico.
Federico Coto F... Fri, 10/01/2010 - 11:25
So it should work.
You mentioned you have an issue when trying to upgrade, what's the error or problem that you're having?
Federico.
