WAN
Answered Question
Oct 1st, 2010
Hello Dears,
DHCP Server is in HUB location and Branch users need to get ip address through HUB. Does the DHCP request passes through WAN ??? when there is a route in routing table of Branch router to the DHCP server.
Is it a Professional Design to do this.??
Correct Answer by gatlin007 about 6 years 6 months ago
This is a widely deployed practice.  It's called DHCP relay.  On a Cisco router or Layer 3 switch try the following:
int fa0/0
description Branch LAN Interface
ip helper-address a.b.c.d ### Where a.b.c.d = the DHCP server address at the Hub site.
exit
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
gatlin007 Fri, 10/01/2010 - 13:48
  • Silver, 250 points or more
int fa0/0
exit
Chris
