Will this work? (RVS4000 config)
Oct 1st, 2010
I have not worked with the lower end routers, so I am working on a hunch.  I have a dlink wireless router handing out addresses through dhcp for public access.  I also have my private network on a switch with a server handing out addresses.  I would like to conect both of these through the RVS4000 but keep them segregated.  If I VLAN the two ports on the switch side of the RVS4000 but do not enable inter-VLAN routing, will this router act as the gateway for both of those subnets?  The wireless router is not capable of tagging the traffic as part of a VLAN.  I can set VLANs on the switch and trunk it to the router, if this router can handle that.  Your thought would be appreciated.  If you have better ideas, I would welcom eth esuggestions.  I have not purchased this router; I am in the design phase.  Budget is an issue.
