Modify SSL VPN "New Password Required" Prompt
Answered Question
Oct 1st, 2010
Anyone know how to modify the SSL VPN "New Password Required" prompt? If it is changable via ASDM i cannot find it! I've been all over the Configure -> Remote Access VPN -> Clientless SSL VPN Access -> Portal -> Customization section but can't find where this particular portion of text gets changed. The issue is that the text that exists there doesn't accurately relfect my organization's password policy.
See the attached image file for the exact section of text I would like to modify.
Ben Posner
Correct Answer by Ivan Kovacevic about 6 years 3 months ago
Hi Ben,
ASDM > Configuration > Remote Access VPN > Language Localization
Expand Templates --> select webvpn --> export --> save the file
Now find the msgid you want to edit and write your own string under msgdtr like so:
#: Mummy.c:5758
#, c-format
msgid "Password expired in %s day(s), if you wish to change now enter a new password with minimum length %s."
msgstr "Insert your string here"
Now import it back at the same ASDM page as
Language: en
Translation Domain: webvpn
You shoud now see your customized string.
Ivan
Overall Rating: 5 (1 ratings)
Correct Answer
Ivan Kovacevic Fri, 10/01/2010 - 15:17
Hi Ben,
#: Mummy.c:5758
#, c-format
Language: en
Ivan
