Can I Change the IP Address on the UCCE 8.0?
Answered Question
Oct 1st, 2010
Hi all
My question is the next:
Can I change the IP Address to the components on UCCE 8.0 (Rogger, ADS, PG, etc)? Is there a procedure for that?
Would appreciate any help and advice
Correct Answer by david.macias about 6 years 7 months ago
Should be pretty simple.  Stop all ICM services, change IP of the servers, update DNS and hostfiles.  Re-run setup for all ICM components update IPs (if used), bring up services.
david
Overall Rating: 5 (1 ratings)
Correct Answer
david.macias Sat, 10/02/2010 - 02:43
  • Blue, 1500 points or more
david
