Forward all incoming calls from specific country to specific extension
Answered Question
Oct 1st, 2010
Using CME 4.1, IOS 12.4(15)T9. Cisco 3825.
How do I route all incoming calls from a certain country to a certain single extension number? Is it even possible?
Can I use the answer-address command together with a destination-pattern command under a inbound dial-peer to accomplish this? I've read the documentation about answer-address, but I don't know if I understand it.
Thanks in advance.
Grant
Correct Answer by Paolo Bevilacqua about 6 years 4 months ago
Yes, you need to use answer-address on a DP on which a translation-profile incoming that sets the desired destination.
Overall Rating: 5 (3 ratings)
Correct Answer
Paolo Bevilacqua Sat, 10/02/2010 - 02:18
Grant Bagdasarian Sat, 10/02/2010 - 05:05
Thank you.
Something like this? +31 is the country code for the Netherlands.
translation-rule 1
rule 1 /316xxxxxxxx/ /765xxxxxx/
translation-profile TEST
translate calling 1
dial-peer voice 1000
answer-address 31T
translation-profile incoming TEST
Udit Mehrotra Sun, 10/03/2010 - 16:18
I will like to add my two cents to Paulo's comment:
If any dial-peer on the incoming call leg is configured with "incoming called-number ." answer address based inbound dial-peer matchiing will fail since incoming called-number scores above answer-address. So remember that you remove any incoming called-number command on inbouund call leg.
