Cisco 1710
Answered Question
Oct 2nd, 2010
is this router good to connect to my adsl so that I replace it instead of the basic modem thet the ISP gives you ?
WIll it help for the new ccnp exam ?
Correct Answer by Federico Coto F... about 6 years 9 months ago
The router is EoL and very old.
But, if it works and you just want to use it as a replacement for a basic modem/lab usage I don't see a problem.
I'm pretty sure the router is not capable of a lot of features that are now part of the CCNP exams, but you can use it for many other things.
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Sat, 10/02/2010 - 17:40
  • Green, 3000 points or more
Federico.
