Two Cisco autonomous APs in bridge mode
Oct 2nd, 2010
I'm wondering if anyone has every used two
1242s in bridge mode with both the 2.4 and the 5GHz radios as part of the link.  If so, would you mind sharing?
If not, does anyone have any lab configs they would be willing to share?  This isn't for production - simply labbing it up as some training for students.
Overall Rating: 4.5 (2 ratings)
Elliott Shawd Sat, 10/02/2010 - 23:20
It won't let you configure both radios for workgroup bridge mode.
Kayle Miller Mon, 10/04/2010 - 06:24
  • Silver, 250 points or more
If your trying to accomplish a Point to Point Bridging soultion it's fairly easy. although you can only do 1 radio at a time (either 2.4Ghz or 5ghz).
I don't presently have a full config I can post here, but I can give  you the biggest pieces of it.
version 12.3
no service pad
service password-encryption
hostname
no logging console
clock timezone GMT -5
ip subnet-zero
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no dot11 igmp snooping-helper
dot11 vlan-name Lab vlan
dot11 ssid LAB-BRIDGE
   vlan
   authentication open
   infrastructure-ssid
   wpa-psk ascii 0
username cisco privilege 15 password 0 Cisco
bridge irb
interface Dot11Radio0   <--- or interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid LAB-BRIDGE
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 36.0 48.0 54.0
channel 5805
station-role root bridge       <------ This should be Root Bridge on 1 side and Non-root on the other
rts threshold 4000
concatenation
infrastructure-client
interface Dot11Radio0.1
encapsulation dot1Q 1
no ip route-cache
bridge-group 254
bridge-group 254 spanning-disabled
interface Dot11Radio0.         <------ This should be the default VLAN if your doing VLANs
encapsulation dot1Q native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.         <------ This should be the same vlan as on the ssid line above.
encapsulation dot1Q
no ip route-cache
bridge-group 255
bridge-group 255 spanning-disabled
interface FastEthernet0.1
no ip route-cache
bridge-group 254
interface FastEthernet0.           <------ This should be the default VLAN if your doing VLANs
no ip route-cache
bridge-group 1
interface FastEthernet0.            <------ This should be the same vlan as on the ssid line above.
encapsulation dot1Q
no ip route-cache
bridge-group 255
interface BVI1
ip address x.x.x.x x.x.x.x
no ip route-cache
ip default-gateway x.x.x.x
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
Please rate useful posts!!
Hope this helps
Kayle
