Using Dual ISP's with ASA5505
Answered Question
Oct 2nd, 2010
for the purpose of a redundency, incase the primary ISP goes down the backup kicks in.
Can this be done with the basic license (max 3 vlans) or you need to have the security plus license. (20 vlans)
Currently not using the 3rd vlan (dmz)
Correct Answer by Kureli Sankar about 6 years 4 months ago
With the base license you do get  3 zone (2 regular zones and 1 restricted zone). But with the restricted zone you can only talk to one vlan either inside or outside.  For redundancy to work when one ISP goes down you would want the 3-rd zone to talk to the inside and outside.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/license.html#wp1330679
With the Base license, the third VLAN must be configured with the no forward interface command to restrict this VLAN from initiating contact to one other VLAN.
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/ef.html#wp1934395
So, you need security plus license so, you will not have this restriction.
-KS
Correct Answer by Jia Liu about 6 years 4 months ago
You would need the security plus license.
Overall Rating: 5 (2 ratings)
Correct Answer
Jia Liu Sat, 10/02/2010 - 15:29
Correct Answer
Kureli Sankar Sat, 10/02/2010 - 15:51
-KS
Nikita Borodavko Tue, 04/02/2013 - 12:01
Can you explain me some in this case.
You said "But with the restricted zone you can only talk to one vlan either inside or outside"
Does this mean that restricted zone can only talk with one other zone?
For example, why we can't do so with ASA base license:
create VLAN 1 for INSIDE
create VLAN 2 for main ISP
create VLAN 3 ( restricted, this VLAN can communicate only with one other, right?) for backup ISP and it will communicate only with VLAN 1 INSIDE.
VLAN 3 (backup ISP) should not communicate with main ISP vlan.
What's wrong with my thinking?
Thanks in advance for your reply
John Peterson Tue, 04/17/2012 - 10:52
It makes sence that you don't need a set plus license to have ISP failover as your outside traffic would never forward traffic to the failover ISP.
