QuickVPN is not connecting using Windows 7 x64
Oct 2nd, 2010
I just finished building a Windows 7 x64 system and I noticed that when I try to use the QuickVPN version 1.4.1.2 software I only get command prompt windows the says something to the effect of "Request timed out..." and then another command prompt windows that remains black. When I close it I get a QuickVPN error message.
I also have a Windows 7 x32 where the software runs great. I was wondering is anyone encountered this problem and if there is a solution for it. Please let me know if more information is needed. I will appreciate any guidance in resolving this problem.
Martin M. Mune
US Army Combat Veteran OIF III
Kimberly Adams Tue, 10/05/2010 - 08:42
  • Silver, 250 points or more
Martin,
I am not really familuar with Quick VPN, but the first thing I think of is does this work wtih 64-bit OS?  This is one of the first places to start, especially since it works with a 32-bit OS.
Kimberly
Related Content
