filtering debug to syslog
Oct 3rd, 2010
cisco 2651xm router
IOS: c2600-adventerprisek9-mz.124-15.T9.bin
I run a sip trunk on my router and I've been monitoring my sip calls to syslog using 'debug ccsip calls' for a day, the log was going fine and suddenly the log is filling up with hundreds of entries as follows:
Oct  2 18:11:09 172.16.1.30 19496: .Oct  2 17:11:11.952: %LINK-4-TOOBIG: Interface ATM0/0, Output packet size of 1506 bytes too big,  -Traceback= 0x814F13E4..(lots of numbers).
I see it's to do with the ATM0/0 port which corresponds to the adsl card I use in the router and I recognise 172.16.1.30  as Vlan1. There's no regular time pattern between entries.
What does this entry actually mean?
Is there a way to configure the debug so it doesn't send these particular messages to the log?
Thanks for any pointers.
Calin Chiorean Mon, 10/04/2010 - 05:21
Hello, according to Cisco.com:
%LINK-4-TOOBIG:
Interface [chars], Output packet size of [dec] bytes too big
An internal software error occurred.
Recommended Action: Copy the message exactly as it appears on the console or in the  system log.  Research and attempt to resolve the issue using the tools and utilities  provided at
http://www.cisco.com/tac.  With some messages, these tools and utilities will supply clarifying  information. Search for resolved software issues using the Bug Toolkit  at  http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl.  If you still require assistance,  open a case with the Technical Assistance Center via the Internet at
http://tools.cisco.com/ServiceRequestTool/create/,  or contact your Cisco technical support  representative and provide the representative with the gathered  information.
Related documents- No specific documents apply to this  error message.
It seems that there is an internal software (IOS) error. From my personal experience it may be that a router reload can fix this error.
Calin
tonyspcrepairs Mon, 10/04/2010 - 05:59
thanks for your response. Do you mean a reload of the IOS or the running-config?
Calin Chiorean Mon, 10/04/2010 - 06:06
I mean reload of your device. Be aware that if this device is productive, local or remote site, if you reload it, you can lose connection to certain services during reload.
Cheers,
Calin
lusandi Mon, 10/04/2010 - 16:37
Hello Tony,
Hope you are doing great,
I would like to let you know that traceback it is going to mean that something failed and the router crashed, I would also like to let you know that the problem that you are having it is going to be related with the MTU of the interface.
Can you post your configuration with out the addressing? or private information?
Can you also try this?
interface DialerX
mtu 1492
Int fa 0/0
ip tcp adjust-mss 1452
I hope this will be helpful.
tonyspcrepairs Tue, 10/05/2010 - 02:26
hi thanks for your response. Your reference to the mtu makes sense, you'll see from my run.config (attached) I'm using mtu 1430 on the atm0/0. I used this figure because it seemed to give the fastest downloads. I don't use intf0/0 ot intf01, I use ports 1/0 to 1/15 on the router's switch module which is vlan1. I'll hold off making any alterations until you've seen the whole config. Thanks and await yours.
