Prepending on import map
Oct 3rd, 2010
Is as-path prepending on an import map a tool that should be available?
I have found that on the IOS I'm testing that the prepending only applied if the same route-map is also setting local preference. Sounds like a bug to me but the bug toolkit is currently unavailable at time of posting.
The problem I wish to solve is to import overlapping routes with different route targets, with one route target's routes being preferred over another. Setting local preference would work, but I'd rather use as-path length as that is the metric we manipulate elsewhere.
If this a method that others have experience with?
Here's a test config:
ip vrf CMPA
rd 1:1
import map RM-CMPA-IMPORT
route-target export 1:1
route-target import 1:1
route-target import 1:2
ip vrf CMPB
rd 1:2
import map RM-CMPB-IMPORT
route-target export 1:2
router bgp 1
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf CMPA
  no synchronization
  network 1.1.1.1 mask 255.255.255.255
exit-address-family
address-family ipv4 vrf CMPB
  no synchronization
  network 2.2.2.2 mask 255.255.255.255
exit-address-family
ip extcommunity-list standard CL-CMPA permit rt 1:1
ip extcommunity-list standard CL-CMPB permit rt 1:2
route-map RM-CMPA-IMPORT permit 10
match extcommunity CL-CMPB
set local-preference 100
set as-path prepend 65000 65000
route-map RM-CMPA-IMPORT permit 20
route-map RM-CMPB-IMPORT permit 10
match extcommunity CL-CMPA
route-map RM-CMPB-IMPORT permit 20
interface Loopback101
ip vrf forwarding CMPA
ip address 1.1.1.1 255.255.255.255
interface Loopback102
ip vrf forwarding CMPB
ip address 2.2.2.2 255.255.255.255
The following outputs show that RM-CMPA-IMPORT is applying prepending, but RM-CMPB-IMPORT is not:
GBLON-SQ41-LVG01#sh ip bgp vpnv4 vrf CMPA
BGP table version is 7, local router ID is 10.196.111.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf CMPA)
*> 1.1.1.1/32       0.0.0.0                  0         32768 i
*> 2.2.2.2/32       0.0.0.0                  0    100  32768 65000 65000 i
GBLON-SQ41-LVG01#sh ip bgp vpnv4 vrf CMPB
Route Distinguisher: 1:2 (default for vrf CMPB)
*> 2.2.2.2/32       0.0.0.0                  0         32768 i
GBLON-SQ41-LVG01#
Peter
Overall Rating: 5 (3 ratings)
Mahesh Gohil Sun, 10/03/2010 - 19:13
  • Silver, 250 points or more
Hi peter,
I have tried this scenario on two of platform (7600 and 10k) and I found i face similar problem,
without setting LP I do not see any path-prepending information in outputs.
but anyway let me try more on this , meanwhile if you can paste output of
sh ip bgp vpnv4 vrf CMPB 1.1.1.1/32
Mahesh
Peter Cresswell Mon, 10/04/2010 - 01:38
Hi Mahesh,
Thank you very much for recreating the issue on those platforms. Here's the output you requested:
GBLON-SQ41-LVG01#sh ip bgp vpnv4 vrf CMPB 1.1.1.1/32
BGP routing table entry for 1:2:1.1.1.1/32, version 6
Paths: (1 available, best #1, table CMPB)
  Not advertised to any peer
  Local, imported path from 1:1:1.1.1.1/32
    0.0.0.0 (via CMPA) from 0.0.0.0 (10.196.111.3)
      Origin IGP, metric 0, localpref 100, weight 32768, valid, external, best
      Extended Community: RT:1:1
      mpls labels in/out nolabel/nolabel(CMPB)
I opened a TAC case about this last night and they are investigating too, i'll post their findings once I know. I have also found that setting a community value also allows the prepending to apply - which obviously is a much less intrusive workaround...
In your experience is changing routing metrics on an import map not a tool that is often used? Or worse, is it not advisable/supported?
Peter
Mahesh Gohil Mon, 10/04/2010 - 01:59
Hi peter,
I always seen that doing something via. import-map is not functioning as per our requirement.
Sometimes we need to clear routes frequently to see affect . But we can't blame untill we have some insight outputs.
Unfortunately there is no more debug options available for troubleshooting.
Inbetween is it possible to try this with any external route. i am not able to create such scenario here.
also please let me know tac reply. i am eager to know that
regards
mahesh
aching02u Wed, 12/14/2011 - 14:12
Hi all
I am in the same situation, do you have any info from the TAC?
thanks
regards
AC
Ivan Krimmel Thu, 12/15/2011 - 02:17
  • Gold, 750 points or more
Guys,
I believe the answer from TAC is:
CSCtj85371 Bug Details
import map with as-path prepend
Symptom:
AS_PATH prepend will only work if there is LOCAL PREF defined inside a outbound routemap. If there is only AS_PATH prepend and no LOCAL_PREF, BGP will not prepend the paths with defined AS values.
Conditions:
AS PATH prepend will not be pre-pended properly
Workaround:
Configure LOCAL_PREF along with AS_PATH prepend.
Fixed-In Fixed-in
15.0(1)M4.5
15.1(3.13)T
12.2(33)SRE3
12.2(33.2.20)SRE
15.1(1)S0.2
15.1(1.22)S
15.0(1.19)DPA12
15.1(3.8.3)PIB
15.2(0.0.12)PIL16
15.0(1)S2.3
15.1(2)T2.2
15.1(1)T2.4
15.1(3)T0.2
15.1(1)S1
15.0(1.19)DPB23
15.0(2.12)DPB1
15.0(1)SY
15.1(1)SG1.3
15.0(1)S3a
15.1(2)GC1
HTH,
Ivan.
