SPA 9000 Repeat Menu
ty.masse
Can someone help me with this?  In my scrip, I need to give the caller an option to press 8 to repeat the menu all over again.  Go back to the top.
How do I do that?  I don't want to use the no input option, since I want the user to press something to go back to the menu again.
I thank you in advance.
Alberto Montilla
Dear Sir;
Look at chapter 7, page 139 of the admin guide. There is an example of the directory...look at "case input" entry, this is what you need to use.
Regards;
Alberto
Thanks for your response.  However, I looked at that section and couldn't find an ex
ample matching mine.  Basically I want to do  the repeat T f
unction, but not by waiting for a timeout.  I want to do it by pressing a button.
  They didn't have a similar example.  Let me know if you have an further ideas or sugg
estion
