Uninstall ACS 4.2 fail
Answered Question
Oct 3rd, 2010
I upgrade ACS from 4.1.4  to 4.2. I need to downgrade back to 4.1.4 without reinstalling W2003 server! But when I remove 4.2 I could not reinstall 4.1.4 because of "4.1.4 must be installed only on top of 4.1.1.x or 4.1.3.x". Using Clean.exe utility does not solve it. Cleaning registry does not solve it. I tried to watch "what was going behind" (find relevant lock file or register) using programs like FileMon anf RegMon, but without success. Thanks for any help in advance. RJ
Correct Answer by aneelaka about 6 years 9 months ago
You must have ACS 4.1 installed before you install ACS 4.1.4. So install ACS 4.1 then upgrade to 4.1.4
Overall Rating: 5 (2 ratings)
jedubois Fri, 10/08/2010 - 13:02
  • Cisco Employee,
     If you have the ACS 4.2 CD there is a support folder -> clean -> clean.exe.  If you run this utility it will completely remove ACS from your system.  If you do not have the ACS 4.2 CD please open a TAC case if you have a contract and we can provide the media for you.  The clean utiltity if version specific so you will need to 4.2 CD to remove the 4.2 install.
--Jesse
Correct Answer
aneelaka Fri, 10/08/2010 - 13:03
jedubois Fri, 10/08/2010 - 14:02
  • Cisco Employee,
Sorry yes this is correct, 4.1.1 must be installed before 4.1.4, teaches me to try to answer questions on a Friday afternoon....
--Jesse
Related Content
