CNA v5.5 crashes
Oct 3rd, 2010
Hi Guys
First time so I hope I'm in the right area.
Installed CNA v5.5 on my laptop. Using XP SP3. CNA runs. However, when I've entered an IP address of a switch it closes the application down. I don't get a box asking for ID and password.
Any ideas most appreciated.
I'm attaching the application log just in case that helps.
mdeprete Tue, 10/05/2010 - 04:39
Hi Brian,
I had a look at the logs, and found nothing that could explain the crash.
Few things to check :
- do you get any error messages in the java console (control panel -> Java -> Advanced -> Show console) ?
- do you get the same problem when CNA is installed on another machine (to rule out any issues with your operating system)
briannz556 Tue, 10/05/2010 - 19:32
Hi Marc
Thanks for your response. But I'm totally puzzled now.
I did as you requested with the Java Console. CNA worked.
I turned off the console and returned to the initial state of my laptop and CNA worked.
NOTHING has changed in my environment. At a loss to explain why CNA now works. On entering an IP address I now get the authentication box to appear whereas before it wouldn't.
I'm marking it down to your presence.
