How to convert to this file type (strange .au file)
Oct 3rd, 2010
Dear all, hope you are doing great!
My customer has a voice gateway (Cisco 2821). He want to record a new prompt for it. Please check the download link for the old prompt file (
He has recorded a new prompt and I have to convert this file to .au with the same properties with I opened with CoolEditPro 2.1 but it asked me for sample rate, codec and I could not hear anything (just like some noisy).
So please analyze this file and tell me how to make it. Thank you very much.
hiepnguyenho Sun, 10/03/2010 - 19:35
One more thing, I have made him another .au file like what I often do (8-bit mulaw, 16bit, mono). I test this file in my 2821 Router and it works normally.
But when I test this file with his Router, it said that there is an error with file format.
Here is the output of his 2821 Router:
NIVR01#audio-prompt load Reload of status failed
audio-prompt not loaded - open (or format) failure
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 12.4(25c), RELEASE SOFTWARE (fc2)
And here is mine:
HAN-R2821-01#audio-prompt load Reload of successful
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
So what is the problem with the router? Thank you very much.
Hiep Nguyen.
