command access-list 102 deny icmp any any echo
Answered Question
Oct 3rd, 2010
Hi all,
i have applied ---
access-list 102 permit ip any any
on my wan int of router.now when i ping my network from outside i get result
ping 96.51.x.x
Pinging 96.51.x.x with 32 bytes of data:
Reply from 96.51.x.x: Destination net unreachable.
Ping statistics for 96.51.x.x:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
My question is when we ping some device we send echo request to that device and if we can reach that device then we get echo reply back from that
device to us.
as per my understanding here when i send 4 packets to router ip 96.51.x.x.  then router reply me by Reply from 96.51.x.x: Destination net unreachable.
saying that it received my packet but as i have done the config  access-list 102 deny   icmp any any echo  it do not send !!.
i have zero packet loss.
let me know please if i am wrong here or not?
thanks
mahesh
Correct Answer by Mahesh Gohil about 6 years 5 months ago
Hi mahesh:
also what is difference between receiving reply from a gateway and host?
It means if you are pinging some host behind router and assume that host is not reachable from router then your router will reply
that destination unreachable. here the IP in your ping command and the reply IP will be different.
if both IP is same then this reply is from end host.
hope this is clear to you
Mahesh
Overall Rating: 5 (1 ratings)
Mahesh Gohil Sun, 10/03/2010 - 20:33
  • Silver, 250 points or more
Hi Mahesh,
Yes ou understand correctly. You can expect below reasons under destination unreachable.
0 = net unreachable;
1 = host unreachable;
2 = protocol unreachable;
3 = port unreachable;
4 = fragmentation needed and DF set;
5 = source route failed.
where
Codes 0, 1, 4, and 5 may be received from a gateway.
Codes 2 and  3 may be received from a host.
As you can see in your case it is net unreachable so I request you to verify the ip returned in "Reply from x.x.x.x" with the IP you used in ping command as this output could be replied by your gateway also.
also you can see counters increased in your access-list to verify that your ping packet is hitting your access list or not
mahesh
mahesh18 Sun, 10/03/2010 - 20:48
hi,
when i did ping again here is result
i ping 4 packets
here is result from router
2650xm#sh access-lists 102
Extended IP access list 102
    10 deny icmp any any echo (764 matches)
    20 permit ip any any (74156 matches)
    10 deny icmp any any echo (765 matches)
    20 permit ip any any (74168 matches)
    20 permit ip any any (74180 matches)
    10 deny icmp any any echo (766 matches)
    20 permit ip any any (74207 matches)
    20 permit ip any any (74225 matches)
    20 permit ip any any (74243 matches)
    20 permit ip any any (74258 matches)
so we can see the packtes are reaching the ACL so it means we are getitng reply from the 2650XM router right?
so here 2650xm as per your note is gateway right ?
other thing i want to know is when i config the command  access-list 102 deny   icmp any any echo reply
then i get the request time out ..... saying send 4 packets received 0   and lost 4.
so this means that my echo packet is reaching the destination router but destination router is blocked for echo reply and it is sending .....
also here when we see the received 0 it means my pc received 0 packet from 96.x.x.x router right?
many thanks
mahesh
danrya Sun, 10/03/2010 - 20:42
  • Bronze, 100 points or more
As the other user said, yes.  If you don't want the message sent back, you can use "no ip unreachables" under the interface.
Dan
Correct Answer
Mahesh Gohil Sun, 10/03/2010 - 21:37
Hi mahesh:
Mahesh
