Can the UCS540 work with 2N helios IP 1 Button Door Entry keypad?
Oct 3rd, 2010
Hi I have the following queries :
1. Will the 2N helios IP 1 Button Door entry keypad work with the UCS540W ? The protocol used by the 2N Helios is SIP. Pls see below the specs:
VOIP: Signalization : SIP
Number of Voice Channels : 2
Audio Codc : G711 PCM, 64Kbps
Video Codec : H264, 64-2048 kbits
Interfaces:
Ethernet 10/100 Base T
Relay Outputs : Max Voltage 30V DC, Maximal current 1 A DC
2. Are there any compatible Door entry systems that have been tested with Cisco UCS ?
3. Will the Sony SNC-DS10 network mini-dome IP camera work with the SPA525G IP Phone for streaming live video ? The Sony camera supports JPEG & MPEG-4 video formats.
Thanks & rgds
Bob Sindhu
David Hornstein Sun, 10/03/2010 - 23:02
Hi Bob,
We have played with a few key door openers  before.  check out a rather excellent posting and Application note  by Marcos Hernandez on the cyberdata intercom and door opener
https://supportforums.cisco.com/search.jspa?peopleEnabled=true&userID=&containerType=&container=&q=cyberdata+
VOIPon  who make your product, suggest that their product is compatable with the following;
  • Cisco Call Manager
  • Linksys
The is referenced from the following URL;
http://www.voipon.co.uk/2n-helios-ip-1-button-keypad-cam-door-entry-panel-9137111cke-p-1487.html
I did run a SIP based cyberdata product on my UC520.  The script below dynamically accepts a SIP client with a MAC address of 0020.F7D8.D008 to make and receive SIP calls.   This part I have tested myself.
My script below taken from my UC520 was basically  plagiarized from Marcos'  Application note referenced above.
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 10
max-pool 10
file text
create profile sync 0115325858050421
voice register dn  1
number 801
no-reg
voice register template 1
anonymous block
voice register pool  1
id mac 0020.F7D8.D008
number 1 dn 1
dtmf-relay rtp-nte
voice-class codec 1
no vad
I have answered your question on the Sony Camera on a previous posting you made.
regards Dave
epasqualotto Tue, 11/02/2010 - 15:43
Hi Bob, I'm working also on it. Unfortunately you have to wait the release 8.5 (this month) or maybe 8.6 (march 2010) for have SIP video endpoint on Cisco CME. I'm waiting for the same stuff because I write a dedicated softphone for it (http://videospindoor.netspin.it)
Enrico Pasqualotto
