10-03-2010 10:26 PM - edited 03-04-2019 09:58 AM
I have configured the vss and tried to traceroute one of the IP from vss switch and started getting below error :
Vss active # traceroute ... ip address ..
" Peer RP index unknown Peer RP index unknown Peer RP index unknown "
when i searched on cisco website i came across below ceveat details :
Unknown | Peer RP index unknown messages seen on VSS setup |
I am not able to understand .. .exactly what it is ?
Your help will be appreciative to get resolve this issue .........
Solved! Go to Solution.
10-04-2010 01:57 AM
I cannot confirm that, as I don't have where to test this now, but Cisco says that this IOS:
12.2(32.8.11)SX247
12.2(33.5.2)SXH
12.2(33)SXI2
12.2(32.8.11)XJC273.1
12.2(32.8.11)YST273.3.1
12.2(32.8.1)YCA273.3
12.2(33)SXH6
Are bug free in regard to CSCsx20862 bug:
You need a CCO account to access that link.
If everything is working fine, I would suggest to stay with the current IOS and upgrade when you have the chance to do it.
Calin
10-04-2010 01:12 AM
Hello!
I've check your bug details and I see that "This issue is cosmetic", so there is no impact on VSS operation, just is unpleasant to see it there.
What IP are you trace to ? Is your trace successful?
If you check the condition: "Any IP packet generated by IP broadcast, such as traceroute and ping destined to
255.255.255.255 address." and problem description: "The above message is reported when the packet got dropped.", these let me the idea that your traceroute is not successful, the packet get dropped and you see this message.
Cheers,
Calin
10-04-2010 01:27 AM
Thanks for your reply.
My trace is successful . I am trying to ping ip address of another branch over WAN.
should i keep as it is ? or is there any way to resolve this ....................
10-04-2010 01:33 AM
According to Cisco, there is no workaround for this behavior, except if you upgrade IOS. It seems that this bug is not affecting:
12.2(32.8.11)SX247
12.2(33.5.2)SXH
12.2(33)SXI2
12.2(33)SXH6
of higher.
As I said in my first post, it will not affect your VSS functionality, but it's upleasant to see the error there. So, you may stay with this error or upgrade IOS (what version do you have?)
Cheers,
Calin
10-04-2010 01:39 AM
below is IOS details.
Router#sho ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASE-M), Version 12.2(33)SXI2a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Sep-09 01:00 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX6, RELEASE SOFTWARE (fc1)
Router uptime is 6 minutes
Uptime for this control processor is 6 minutes
Time since Router switched to active is 5 minutes
System returned to ROM by power cycle at 07:30:34 UTC Tue Apr 27 2010 (SP by power on)
System image file is "sup-bootdisk:s72033-ipbase-mz.122-33.SXI2a.bin"
Last reload reason: Reload Command
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC1408004X
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
75 Gigabit Ethernet interfaces
10 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thanks for your quick response.
10-04-2010 01:50 AM
You have 12.2(33)SXI2a, and Cisco recommend that 12.2(33)SXI2 is bug free. In my head also SXI2a should be bug free, but if this switch is in a test environment or if it doesn't affect productivity (I see that it is up only for 6 minutes) can you download and boot with 12.2(33)SXI2 IOS image? In this way you can see if Cisco is right and your problem should be fixed. If it's not working with 12.2(33)SXI2 you should open a TAC case, if your device is covered by a support contract.
Cheers,
Calin
10-04-2010 01:54 AM
No, this is in production and it is working fine ,.... i can not disturb the set-up till it finalize or confirm that this is bug and i have to go for IOS upgradation.
Is it possible for you to confirm that this is bug and my IOS is not bug free and i have to go for IOS upgradation.
Thanks for sharing knowledge.
10-04-2010 01:57 AM
12.2(32.8.11)SX247
12.2(33.5.2)SXH
12.2(33)SXI2
12.2(33)SXH6
Calin
10-04-2010 02:03 AM
Thanks for your reply and sharing valuable knowledge with me.
10-04-2010 02:05 AM
You're welcome and good luck!
Calin
10-04-2010 02:07 AM
Looking forward to keep in touch with you ..................
Shall i be in touch through your email ID .......... if you could share............. ?
