Command set permitting all show commands
Oct 3rd, 2010
Hi guy,s
Having problem with permitting with command sets in ACS 5.2
i want to give a user access to all show command
this doesn't work
any idea's
Overall Rating: 5 (1 ratings)
Federico Lovison Thu, 10/07/2010 - 12:53
Hi Peter,
When you say that it doesn't work, do you mean that no "show" commands are allowed, or actually some of them work?
What commands did you test with? If any command works.. what are the working and non-working ones?
Did you configure authorization in orde to return a privilege level through the shell profile that is suitable for the show commands that you're testing?
What errors do you get on the ACS and/or on the switch?
I hope this helps!
