reset NAC manger and server to factory default
Answered Question
Oct 4th, 2010
I have NAC appliance CAM version 4.7(3) i want to reset it to its factory default or clea all configuration
and the sme with the server.
Correct Answer by Faisal Sehbai about 6 years 3 months ago
Wael,
Elly is right. For production systems if you want to start from scratch, best idea is to re-image.
If you're in a lab setup, you can nullify the database on the CAM by running the following commands:
- service perfigo stop
- dropdb -h localhost -U postgres controlsmartdb
- createdb -h localhost -U postgres controlsmartdb
- psql -h localhost -U postgres controlsmartdb <  /perfigo/dbscripts/pg_createtable.sql
- service perfigo start
On CAS, you can delete the /perfigo/access/bin/env file and reboot.
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Overall Rating: 5 (1 ratings)
Elly Bornstein Mon, 10/04/2010 - 09:12
The only way to get a clean install is to reformat.
Everything should be reconfigurable, is there a certain thing you want to reconfigure?
Correct Answer
Faisal Sehbai Mon, 10/04/2010 - 13:34
Wael,
HTH,
Faisal
