10-04-2010 03:54 AM - edited 03-04-2019 09:59 AM
We have PTP link btw two sites, when we did failover test on the link, the X sites of VLANs were able to reach site Y site. But only one VLAN not able to reach the Y site from X site.
In a N/W cloud, X site hooked with xxxx B/W and Y site with xxx B/W. However the failover PTP link btw these two sites is xxx B/W.
LAN routing protocol is EIGRP.
My only concern is that only only one VLAN not able to reach the Y site from X site. What could be the issue?
10-04-2010 03:56 AM
A configuration mistake.
10-04-2010 05:32 AM
Not sure how you expect us to answer this with the details provided. I would think the most likely culprit would be a missing route for the vlan in site Y so that return traffic cannot get back to site X.
Check your routing tables at both ends of the link to make sure all routes are present. If they are then it would help if you could provide some more details and some configurations.
Jon
