CAD Agent Desktop - Making 2nd call to Back office staff
Answered Question
Oct 4th, 2010
Hi All,
Does anyone have a solution to the following question from a customer?
“Whilst an agent is talking to a caller, it would appear that the only option available to make a second call at the same time ie. in the case where a member of call centre staff wishes to talk to the back office team whilst the customer is on hold, the agent can put the caller on hold using CAD, however they would need to press the “New Call” button on the physical telephone to dial the 2nd number as the “Make Call” feature is not available within CAD (whist the call is on hold).
The agent will frequently make a 2nd call whilst on the phone to a customer. Not being able to use CAD to make this second call will cause a lot of confusion! Is there any way around this problem?”
I know that the ‘make call’ button is disabled when the agent is in a ready state, so how do they make a 2nd call if need? I suppose they could place the caller on hold and go not ready but I’m not sure if CAD allows this (I’m away from a test lab to check) and this would affect the agent stats.
Or perhaps they could initiate a supervised transfer discuss what they need to with the back office staff member then cancel the transfer and use the alternate button to switch between caller and back office staff?
Any suggestions would be grateful.
Thanks Chris
Correct Answer by Jonathan Schulenberg about 6 years 6 months ago
Using a supervised transfer and then cancelling out of it is the only option with CAD for now. I suggest that you submit a feature request through your Cisco AM to resolve this.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Tue, 10/05/2010 - 05:58
  • Cisco Designated VIP,
    2017 IP Telephony
