Load balancing over FR not working
Oct 4th, 2010
Hey gang!  I'm having some issues with what would appear to be a straightforward config.  I've got two frame relay T1s going into a 7204, and am trying to per-packet load balance across the two using static routes.  The problem is that I can only get 1.6 Mb/s throughput max when trying to load balance, even though I can get 1.4 Mb/s throughput on each T1 individually.  In other words, if I take out either of the routes or shut down either T1, I can get a solid 1.4 Mb/s transfer rate across the remaining link.  But with both T1s up and both routes in place, I'm only getting 1.6 Mb/s (distributed evenly across both T1s.)  One fly in the ointment that I don't know the ramifications of is that the other end of the link is ATM, and I don't have that config immediately handy but can get it changed if necessary.  Any ideas what might be going on?  Selected config is below, along with "show interface" during a transfer with both T1s up.  Thanks!
version 12.2
ip cef
controller T1 1/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 1/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 33.74.246.130 255.255.255.248
load-interval 120
duplex full
interface Serial1/0:1
bandwidth 2000
no ip address
encapsulation frame-relay IETF
load-interval 120
fair-queue
frame-relay lmi-type ansi
interface Serial1/0:1.2 point-to-point
ip address 33.74.252.14 255.255.255.252
ip load-sharing per-packet
frame-relay interface-dlci 16
interface Serial1/1:1
bandwidth 2000
no ip address
load-interval 120
fair-queue
interface Serial1/1:1.1 point-to-point
ip address 33.74.252.10 255.255.255.252
frame-relay interface-dlci 17
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1/0:1.2
ip route 0.0.0.0 0.0.0.0 Serial1/1:1.1
#sh int
FastEthernet0/0 is up, line protocol is up
  Hardware is DEC21140A, address is 0018.18f8.2e00 (bia 0018.18f8.2e00)
  Internet address is 33.74.246.130/29
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 4/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:56:28, output 00:00:00, output hang never
  Last clearing of "show interface" counters 10:34:28
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  2 minute input rate 1616000 bits/sec, 156 packets/sec
  2 minute output rate 76000 bits/sec, 143 packets/sec
     731598 packets input, 149259920 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     1229096 packets output, 1512570370 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Serial1/0:1 is up, line protocol is up
  Hardware is Multichannel T1
  MTU 1500 bytes, BW 2000 Kbit, DLY 20000 usec,
     reliability 255/255, txload 102/255, rxload 4/255
  Encapsulation FRAME-RELAY IETF, crc 16, Data non-inverted
  LMI enq sent  3807, LMI stat recvd 3807, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 0  LMI type is ANSI Annex D  frame relay DTE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 634/0, interface broadcasts 0
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 10:34:29
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/7/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1500 kilobits/sec
  2 minute input rate 34000 bits/sec, 73 packets/sec
2 minute output rate 807000 bits/sec, 82 packets/sec
     617010 packets input, 750004472 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     370924 packets output, 71287468 bytes, 0 underruns
     0 carrier transitions
  no alarm present
  Timeslot(s) Used:1-24, subrate: 64Kb/s, transmit delay is 0 flags
Serial1/0:1.2 is up, line protocol is up
  Internet address is 33.74.252.14/30
  MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Serial1/1:1 is up, line protocol is up
  Last input 00:00:04, output 00:00:00, output hang never
     Conversations  0/9/256 (active/max active/max total)
  2 minute output rate 806000 bits/sec, 82 packets/sec
     616782 packets input, 750083692 bytes, 0 no buffer
     Received 0 broadcasts, 8 runts, 0 giants, 0 throttles
     8 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     370991 packets output, 71400072 bytes, 0 underruns
  no alarm present
Serial1/1:1.1 is up, line protocol is up
  Internet address is 33.74.252.10/30
paolo bevilacqua Mon, 10/04/2010 - 05:18
  • Hall of Fame,
    Founding Member
Since per-packet load balancing causes out-of-order packet arrival, what likely it's happening, is that the systems are wasting a lot of bandwidth in trying to recover from that, with continuous retransmission and transmit window resets. You can verify that looking at the TCP statistics of the systems involved.
Conclusion: either use a mechanism like MLPPP that guarantees in-sequence packet arrival, or do not use per-packet load balancing.
rhaskell Mon, 10/04/2010 - 07:21
Thanks Paolo.  We did try MLPPP (as illustrated here: https://supportforums.cisco.com/message/740711#740711 ,) but had difficulty getting the multilink interfaces to come up and couldn't figure it out (possibly due to the fact that it's FR on one end and ATM on the other.)  I'll have to take a closer look at the traffic content and check for retransmissions as you suggest.
paolo bevilacqua Mon, 10/04/2010 - 07:34
  • Hall of Fame,
    Founding Member
I understand and believe that for some reason is often difficult to have a stable MLPPP over a FR/ATM network like your, however if your objective is the maximum single-session performance, I think there is no alternative.
Related Content
