LMS 2.6/CV 6.1.5 : installing DtShare.cv50.v1-2.zip
Oct 4th, 2010
I would like to know how install DtShare.cv50.v1-2.zip ?
I need to install it before installing Cat3750.cv50.v10-0.zip.
I didn't find readme.
Many thanks, Elisabeth
Nael Mohammad Tue, 10/05/2010 - 00:16
The simplest way is to use Common Services ---> Software Center ---> Device Update ---> Select CiscoView and check for updates. You might have to select all the applications such as common services and rme to install the additional device packages. After selecting the updates, select to Install Device Packages.
ebezombes Tue, 10/05/2010 - 00:43
I would like to install package using command line because I don't want restart process.
I don't think that when installing CV package you need to restart lms process if you install package using command line.
Nael Mohammad Tue, 10/05/2010 - 09:16
Even installing from the CLI will require a restart of the CiscoWorks LMS Daemon manager so that the changes can take effect. To install the from the CLI do as follows:
PSUCLI -p cvw -install -src
For example: PSUCLI -p cvw -install -src C:\psu_download\cvw
