FireFox SSL VPN Issue
Oct 4th, 2010
I am having some issues with Firefox through the ssl vpn.  We have a web site that is heavy in java code and Firefox is giving me script timeout errors.  Everything works fine in IE.  Firefox works fine if I go to the internal site outside of the ASA.  I am running 8.3.2 on the 5550 ASA.  I have upped the timeout on Firefox to allow the script logger to run but it does not make a difference.  If I click continue the script never completes and the site hangs.  I have disabled compression and cache.
A script on this page may be busy, or it may have stopped responding. You can stop the script now, or you can continue to see if the script will complete.
Script: https://internalsite.com/+CSCOL+/cte.js:9
Shilpa Gupta Mon, 10/04/2010 - 05:49
  • Cisco Employee,
Is the smart tunnel enabled?
If not, can you please  enable it  and try again.
Shilpa
nwlogical Mon, 10/04/2010 - 05:50
I have tried smart tunnel and the results are the same.
nwlogical Mon, 10/04/2010 - 13:23
For some reason the url to some images are being tacked onto by the asa witch is causing 404 errors.
img/goToActivity.gif%3Cdiv%20class=
This, %3Cdiv%20class= should not be there and does not look this way in IE.
