Logging FWSM
Answered Question
Oct 4th, 2010
Hello Dears,
I can't see any logs on FWSM when i do sh logging.  Below is the output and command what i have entered in the configuration.
logging enable
logging buffer-size 8096
logging asdm-buffer-size 512
logging trap debugging
logging asdm debugging
logging queue 8192
logging host MGMT 172.24.10.10
logging host MGMT 172.24.10.11
FWSM(config)# sh logging
Syslog logging: enabled
    Facility: 20
    Timestamp logging: disabled
    Standby logging: disabled
    Deny Conn when Queue Full: disabled
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging: disabled
    Trap logging: level debugging, facility 20, 227608597 messages logged
        Logging to MGMT 172.24.10.10 errors: 143  dropped: 32864
        Logging to MGMT 172.24.10.11 errors: 277934  dropped: 41712784
    History logging: disabled
    Device ID: disabled
    Mail logging: disabled
    ASDM logging: level debugging, 227608597 messages logged
Correct Answer by praprama about 6 years 9 months ago
I am not sure i am the right person to answer this as i do not have lot of experience with designing or working with networks. I am sure there are other better people out there who can help you with some tools, etc to help you with your requirement.
I can try my best to suggest workarounds as situations arice and provide ways of securing your network.
Cheers,
Prapanch
Overall Rating: 5 (1 ratings)
praprama Mon, 10/04/2010 - 05:59
  • Cisco Employee,
Please add the command "logging buffered debugging" and then you should see logs in the "show logg" output.
As a side note, I owuld suggest you not to have these many syslog destinations enabled on the FWSM as there is a high chance of overloading it and resulting in issues. Please disable ones you think can be done away with.
Thanks and Regards,
Prapanch
estelamathew Mon, 10/04/2010 - 06:18
Thanks Prapanch,
I will do it tomorrow as i m out of office i will update u.  Prapanch how i can check the health of My Network.??? If u can help me with your expierience.
Correct Answer
praprama Mon, 10/04/2010 - 06:41
  • Cisco Employee,
Cheers,
Prapanch
