No version for outlook for MAPI in CM and CLI
Oct 4th, 2010
Any resond why we are not seeing  any version for outlook for MAPI in CM and CLI?
Using version 4.2.1 and 4.2.3 on the WAE's
#sh statistics accelerator mapi
MAPI:
   Global Statistics
   Time Accelerator was started:                                      Sat Sep 18 18:04:41 2010
   Time Statistics were Last Reset/Cleared:                           Sat Sep 18 18:04:41 2010
   Total Handled Connections:                                         37163
   Total Optimized Connections:                                       31591
   Total Connections Handed-off with Compression Policies Unchanged:  5565
   Total Dropped Connections:                                         7
   Current Active Connections:                                        110
   Current Pending Connections:                                       0
   Maximum Active Connections:                                        147
   Total Secured Connections:                                         1108
   Number of Synch Get Buffer Requests:                               0
   Minimum Synch Get Buffer Size (bytes):                             0
   Maximum Synch Get Buffer Size (bytes):                             0
   Average Synch Get Buffer Size (bytes):                             0
   Number of Read Stream Requests:                                    0
   Minimum Read Stream Buffer Size (bytes):                           0
   Maximum Read Stream Buffer Size (bytes):                           0
   Average Read Stream Buffer Size (bytes):                           0
   Minimum Accumulated Read Ahead Data Size (bytes):                  0
   Maximum Accumulated Read Ahead Data Size (bytes):                  0
   Average Accumulated Read Ahead Data Size (bytes):                  0
   Local Response Count:                                              0
   Average Local Response Time (usec):                                0
   Remote Response Count:                                             0
   Average Remote Response Time (usec):                               0
   Number Of Write Stream Requests:                                   0
   Minimum Async Write Stream Buffer Size (bytes):                    0
   Maximum Async Write Stream Buffer Size (bytes):                    0
   Average Async Write Stream Buffer Size (bytes):                    0
   Current 2000 Accelerated Sessions:                                 0
   Current 2003 Accelerated Sessions:                                 0
   Current 2007 Accelerated Sessions:                                 0
   Current 2010 Accelerated Sessions:                                 0
   Lower than 2000 Sessions:                                          0
   Unsupported Higher Client Version Sessions:                        0
Jan
pevaneyn Tue, 10/26/2010 - 03:40
Hello Jan,
The fact that the versions information is not filled in might indicate that the MAPI connections are in fact encrypted. The "Total Secured Connections: " makes me think that this is in fact what we are seeing.
Are you seeing MAPI AO accelerated connections? Do you see acceleration happening? Can you check if disabling MAPI encryption solves this problem?
Best regards, Peter
