LMS 3.2 DFM error "URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!"
Oct 4th, 2010
Hi Joseph,
one of our client is using lms 3.2 and getting the following error in DFM -> device import -> Auto Allocation mode configuration.
Error in getting instance of TreeGenerator class
com.cisco.nm.trx.kdm.utils.DcrGroupSelectorTreeGenerator
Root Cause:com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
I have gone through all documents available in netpro and done all tests mentioned for trouble shooting
following is the result of command " pearl resolver.pl "
D:\CSCOpx\bin>perl resolver.pl hyd-wbpo-cwks.wipro.com
Original name: hyd-wbpo-cwks.wipro.com
Hostnames/IP Addresses:
        hyd-wbpo-cwks.wipro.com/10.120.232.143
Here with I have attched the dfmserver.log, dfmserver1.log, dfmOGSserver.log , netstat -a -n -o -b, and output of PDshow.
One thing I observed when I am running the command "brcontrol"  under "D:\CSCOpx\objects\smarts\bin>" it is not returning me any output.
All the devices in dfm are stacked in learning state at 10%. The SNMP RO string used in DCR is alos ok.
Satya
