10-03-2010 08:58 AM - edited 07-03-2021 07:14 PM
Hello all,
Goal: Setting up a new multifloor building and the goal is to have total ability to roam between floors without dropping connections using the follwing:
5508 controllers
1142 LAP's
Layer 3 connected network EIGRP between floors
No layer 2 trunking between distribution switches for better failover
See attached diagram
Vlan 200 is /22 network for Wireless Client
Configuration of switchport with controller:
interface GigabitEthernet4/46
description nwc01-1211-01b
switchport
switchport trunk native vlan 210
switchport trunk allowed vlan 200,208,210
switchport mode trunk
wrr-queue bandwidth 50 255
wrr-queue queue-limit 75 15
wrr-queue random-detect min-threshold 2 70 100
wrr-queue random-detect max-threshold 2 90 100
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 1 2 3 4
wrr-queue cos-map 2 2 6 7
mls qos trust cos
auto qos voip cisco-phone
channel-group 200 mode on
Configuration of switchport with LAP
switchport
switchport mode access
mls qos trust cos
spanning-tree portfast
end
Basically since we are not doing DOT1Q trunking between the core switches I cannot place my Access Points in vlan 200 per floor. I can them an IP using the access VLAN but I want to distribute IP's address to the clients from the WLC.
The thought process is because the LAP creates an LWAPP tunnel back to the controller then I should be able to centrally distribute IP addresses from the 200 vlan.
I apologize for the confusion but I have a hard time explaining this through the forum.
Solved! Go to Solution.
10-05-2010 05:31 AM
Jake,
The AP does not need to be in VLAN 200, they can belong to any VLAN so long as it can route to the wlc's mgmt interface, tehy will join. ALl client traffic is tunneled back to the WLC for ingress/egress. So if you want your clients to be in VLAN 200, it will work, so long as the WLC has L2 access to that VLAN.
10-05-2010 05:31 AM
Jake,
10-13-2010 06:46 PM
Yes this was the answer. The concept I was missing in all of the WLC configurations was Dynamic interfaces attached as you said to a L2 vlan. The switch port then has the trunks for those accepted vlans.
Thank you,
10-13-2010 08:36 PM
Jake,
Make sure you have a layer 2 adjacency between your distros where your WLCs live for your wireless VLANs. Trunk between the two for better fail over.
