10-04-2010 07:49 AM
I have a WAP4410N that I am trying to get to work on multiple VLANs. Here is the scenario
The WAP is plugged into a cisco switch. The port on the switch is trunked. I have 2 VLANs on this network VLAN 1 for business and VLAN 2 for guest access.
I have 2 routers plugged into the same switch. Each being on their respective VLAN and each handing out DHCP for their subnet.
When I hard wire into each VLAN, the routers give me the IP address for their respective network. So I know everything works when hard wired
The WAP4410N is setup with 2 unique SSIDs both running WPA2-Personal security. The WAP has the most recent firmware on it, 2.0.3.3. On the VLAN page, I have setup the SSIDs where SSID1 connects to VLAN 1 and SSID2 connects to VLAN 2.
I can connect to SSID1 with no issue and get handed a DHCP address. I cannot connect to SSID2, or at least get an IP address from the router for VLAN 2. I have tried to hard code my IP address to my Wireless and ping the router, but get no response from the router.
So I dont think that I am getting connected to VLAN 2 via the WAP4410N.
Any suggestions would be MOST appreciated.
Michael
05-26-2015 09:50 AM
Exactly the same problem here - except that I installed the latest firmware 2.0.7.4...
Did you find a fix?
06-16-2015 02:20 PM
06-23-2015 07:19 AM
It turned out to be a problem between two of our switches and not between the AP and the switch.
Now it seems to work.
Anyway, thanks for your help!
06-19-2015 12:22 PM
Hello
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry to hear that you are experiencing this issue. What switch are you plugging the WAP into? What does the VLANs look like on it? What is tagged and what is untagged? Is your router doing tagging as well? What is supplying the DHCP for your different vlans?
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
06-23-2015 07:17 AM
It turned out to be a problem between two of our (Cisco) switches (SF-200, SG-300) and not between the AP and the switch.
DHCP is provieded by a VM behind a VMware virtual switch with multiple VLANs.
But the option "VLAN Tag" ["Tagged" or "Untagged"] (for VLAN "Enabled") still confuses me...
What is it good for?
