Service Policy Counters have delay in tagging EF traffic
Oct 4th, 2010
I have a customer that was having voice quality issues across a new T1. I implemented QOS, tagging UDP traffic outbound over the serial interface as EF. When I did a show policy-map int ser0/0/0:0 I didn't see the EF tagged traffic Packets marked increment. I did verify the access list was being hit. I let the policy go through the next business day and then logged into the router and see Packets Marked 375641 and the quality was better. Is there a delay on the counter? Any idea why this could happen?
class-map match-all h323
match access-group 102
class-map match-all voice
match access-group 101
policy-map voice
class voice
  set dscp ef
  priority percent 33
class h323
  set dscp af31
  bandwidth percent 5
class class-default
  fair-queue
interface Serial0/0/0:0
bandwidth 2048
no ip address
encapsulation frame-relay IETF
no ip route-cache cef
no ip route-cache
frame-relay lmi-type ansi
service-policy output voice
interface Serial0/0/0:0.60 point-to-point
ip address x.x.x.x/x
ip nbar protocol-discovery
no ip route-cache
snmp trap link-status
no cdp enable
frame-relay interface-dlci 60
access-list 101 permit udp any any range 16384 32767
Felipe Garrido Fri, 10/08/2010 - 06:35
  • Cisco Employee,
Are you using a Cisco voice solution or 3rd party? The RTP port range can vary. Can you post the exact output seen?
-Felipe
