Warning message
AD SSO with 2008 server
Answered Question
Oct 5th, 2010
  • Bronze, 100 points or more
I have windows 2008 server running with NAC 4.7.2 but all users are running xp so AD SSO is possible or not because as per Cisco , vista should be installed.
"You must use  Windows Server 2008 with KTPass version 6.0.6001.18000, and client  machines must be running Windows Vista with Cisco NAC Agent version  4.7.1.15 installed, to ensure you are able to maintain FIPS 140-2  compliance and support AD SSO. "
Is there any workaroun?
Correct Answer by Faisal Sehbai about 6 years 10 months ago
Nomair,
Workaround: Forget KTPASS exists!
Check your settings per this link and make sure that the accounts are showing up correctly as they do in AD:
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/48/cas/s_adsso.html#wp1300720
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Tue, 10/05/2010 - 07:35
  • Gold, 750 points or more
Nomair,
HTH,
Faisal
nomair_83 Wed, 10/06/2010 - 00:01
Faisal bhai,
Should I upgrade to 4.8 or 4.7.2 also support above workaround?
R/g
Faisal Sehbai Wed, 10/06/2010 - 09:52
Nomair,
Valid for 4.7.2 also.
HTH,
Faisal
