Anyconnect client (vpnui) startup issue
Oct 6th, 2010
We want to establish automatic anyconnect vpn creation from a browser.
Vpnui.exe is unfortunately not scriptable and thus we have written a custom application for the anyconnect vpnapi.dll
The browser initiated application connects and after successful connection the program detaches from the vpnapi and attempts to start the vpnui.exe.
This would ideally start the normal anyconnect ui in the traybar in state connected, giving the user a standard way to disconnect.
This works in some environments, but in other vpnui terminates immediately with error
Cisco AnyConnect VPN Client GUI exiting, version 2.5.1025 , return code 100003 [0x000186A3]
A full event log is attached
If the anyconnect gui is started manually by the user afterwards the desired behavior is observed – vpnui is minimized in traybar in state connected
Peter Buus
Signaturgruppen
peterbuus Thu, 10/14/2010 - 23:30
I found the reason - just letting other in same situation know the solution:
It is not enough for the custom application to call vpnapi.detach() - the process has to be terminated.
Cisco AnyConnect VPN Client GUI exiting, version 2.5.1025 , return code 100003 [0x000186A3] indicates that another process that has connected to vpnapi.dll is still running. Regardless of the other process has called vpnapi.detach()
Thus my solution is
CustomAppA establishes VPN connection calling vpnapi.dll
CustomAppA calls CustomAppB and terminates
CustomAppB assures that CustomAppA has terminated and starts vpnui.exe
/peter
