10-06-2010 03:44 AM - edited 03-21-2019 03:06 AM
I have the uc-560 and a GSM gateway
The outgoing call on GSM gateway are working fine, but incoming call are rejected
I have created a SIP trunk account for the GSM gateway, but he stil not registered
How can I solve it ?
Thanks in advance
Solved! Go to Solution.
10-15-2010 11:08 AM
You can see that the provider is failing on the registration attempt:
Sent:
REGISTER sip:172.25.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.0.1:5060;branch=z9hG4bK1992269
To: <79526723>
Date: Fri, 08 Oct 2010 16:25:06 GMT
Call-ID: 66AA8803-D21911DF-881DEFB4-7D00ADBA
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1286555106CSeq: 54 REGISTER
Contact: <79526723>
Expires: 3600
Supported: path
Content-Length: 079526723>79526723>79526723>
000910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 501 Not Implemented
To: <79526723>
Max-Forwards: 70
CSeq: 54 REGISTER
Contact: <79526723>
Expires: 360079526723>79526723>79526723>
Supported: path
Content-Length: 0
Is '79526723' a fully qualified number for where you are located? Is this the number the provider wants you to register with? Can you find out why they are throwing the 501 for registration request? Have you confirmed that the provider does require registration of the number?
10-06-2010 08:34 AM
What number are you supposed to register to the provider with? Is that number configured on the system? Typically you add it as a secondary number to your operator extension. Something like:
ephone-dn 5 dual-line
number 301 secondary 5551234567 no-reg primary
That will get the router to try to register that number to the registrar. You can see the status of that with:
sh sip-ua reg stat
If you still have issues, get 'debug ccsip mess' during while the timer for the above command rolls over.
Also, you don't need a username/password for authentication on this trunk?
10-08-2010 02:13 AM
I made the modification as you ask
But the problem remain the same
ephone-dn 29 dual-line number 220 secondary 99257890 no-reg primary
C_560_EBACCION#show sip-ua register status Line peer expires(sec) registered P-Associated-URI ============ ============= ============ =========== ================ 99257890 20110 16 no UC_560_EBACCION#
Sould I create a dial peer 20110 ?
please help
10-08-2010 06:28 AM
Registration on that number is failing. Run 'debug ccsip mess' and observe the output of the register message for that number and what the provider's response is.
10-08-2010 09:25 AM
see below
000906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:226@172.25.0.1:5060 SIP/2.0Max-Forwards: 70Via: SIP/2.0/UDP 172.25.0.3:5060;branch=z9hG4bK-158028959-CX00From: <78273829>;tag=7C1EB3001750-46016091To: <226>Call-ID: 7C1EB3001750-110012660@172.25.0.3CSeq: 7 INVITEContact: <78273829>User-Agent: 2N VoiceBlue V-02.07.35i30Allow: INVITE, BYE, ACK, CANCEL, OPTIONS, REFER, NOTIFYContent-Type: application/sdpContent-Length: 260v=0o=VoiceBlue 51132 9441 IN IP4 172.25.0.3s=GSM callc=IN IP4 172.25.0.3t=0 0m=audio 8050 RTP/AVP 18 8 0 101a=rtpmap:18 G729/8000a=fmtp:18 annexb=noa=rtpmap:8 PCMA/8000a=rtpmap:0 PCMU/8000a=rtpmap:101 telephone-event/8000a=fmtp:101 0-11
000907: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server ErrorVia: SIP/2.0/UDP 172.25.0.3:5060;branch=z9hG4bK-158028959-CX00From: <78273829>;tag=7C1EB3001750-46016091To: <226>;tag=4BC71F0-1D4Date: Fri, 08 Oct 2010 16:25:01 GMTCall-ID: 7C1EB3001750-110012660@172.25.0.3CSeq: 7 INVITEAllow-Events: telephone-eventServer: Cisco-SIPGateway/IOS-12.xContent-Length: 0
000908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:226@172.25.0.1:5060 SIP/2.0Max-Forwards: 70Via: SIP/2.0/UDP 172.25.0.3:5060;branch=z9hG4bK-158028959-CX00From: <78273829>;tag=7C1EB3001750-46016091To: <226>;tag=4BC71F0-1D4Call-ID: 7C1EB3001750-110012660@172.25.0.3CSeq: 7 ACKContact: <78273829>User-Agent: 2N VoiceBlue V-02.07.35i30Allow: INVITE, BYE, ACK, CANCEL, OPTIONS, REFER, NOTIFYContent-Length: 0
000909: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:172.25.0.3:5060 SIP/2.0Via: SIP/2.0/UDP 172.25.0.1:5060;branch=z9hG4bK1992269From: <79526723>;tag=4BC84EC-16C9To: <79526723>Date: Fri, 08 Oct 2010 16:25:06 GMTCall-ID: 66AA8803-D21911DF-881DEFB4-7D00ADBAUser-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Timestamp: 1286555106CSeq: 54 REGISTERContact: <79526723>Expires: 3600Supported: pathContent-Length: 0
Received:
SIP/2.0 501 Not ImplementedVia: SIP/2.0/UDP 172.25.0.1:5060;branch=z9hG4bK1992269From: <79526723>;tag=4BC84EC-16C9To: <79526723>Date: Fri, 08 Oct 2010 16:25:06 GMTCall-ID: 66AA8803-D21911DF-881DEFB4-7D00ADBAUser-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Timestamp: 1286555106CSeq: 54 REGISTERContact: <79526723>Expires: 3600Supported: pathContent-Length: 079526723>79526723>79526723>79526723>79526723>79526723>78273829>226>78273829>226>78273829>78273829>226>78273829>
see the uc-560 sip trunk printsreen attached
Please help
10-15-2010 11:02 AM
see again the debug output
I am using a gsm gateway with 2 SIM card from 2 different operator
The uc ask a company main number to be used as outgoing caller ID
wich number should i use
May be the problem come from there
Please help
debug ccsip messages
004438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:201@0.0.0.0:5060 SIP/2.0
Max-Forwards: 70
Via: SIP/2.0/UDP 192.168.1.3:5060;branch=z9hG4bK-152027812-CX00
From: <67893567>;tag=7C1EB3001750-22900118067893567>
To: <201>201>
Call-ID: 7C1EB3001750-81015425@192.168.1.3
CSeq: 17 INVITE
Contact: <67893567>67893567>
User-Agent: 2N VoiceBlue V-02.07.35i39
Content-Length: 261
v=0
o=VoiceBlue 23785 14378 IN IP4 192.168.1.3
s=GSM call
c=IN IP4 192.168.1.3
t=0 0
m=audio 8048 RTP/AVP 18 8 0 101
a=fmtp:18 annexb=no
a=fmtp:101 0-11
004439: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
004440: //-1/0B5ABB929762/SIP/Error/sact_idle_new_message_invite: Invalid URL in incoming INVITE
004441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: <201>;tag=291E5698-1A4B201>
Date: Fri, 15 Oct 2010 16:56:52 GMT
CSeq: 17 INVITE
Reason: Q.850;cause=100
Content-Length: 0
004442: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:201@0.0.0.0:5060 SIP/2.0
Max-Forwards: 70
CSeq: 17 ACK
Content-Length: 0
004443: //-1/0B5ABB929762/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x87EB3A08
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number :
Called Number : 201
Source IP Address (Sig ): 192.168.1.1
Destn SIP Req Addr:Port : 192.168.1.3:0
Destn SIP Resp Addr:Port : 192.168.1.3:5060
Destination Name : 192.168.1.3
004444: //-1/0B5ABB929762/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 100
Disconnect Cause (SIP) : 400
10-15-2010 11:08 AM
Sent:
To: <79526723>
Max-Forwards: 70
Contact: <79526723>
Expires: 3600
Supported: path
Received:
To: <79526723>
Max-Forwards: 70
CSeq: 54 REGISTER
Contact: <79526723>
Supported: path
Content-Length: 0
10-15-2010 11:11 AM
For this, you can see that the INVITE coming in has a TO header with an invalid IP:
Received:
Max-Forwards: 70
To: <201>201>
CSeq: 17 INVITE
Content-Length: 261
That invite should have a valid IP in there. Something is stripping that to 0's, perhaps? Or maybe that's behavior of the sending SIP proxy as a result of you not being registered?
10-16-2010 04:29 AM
See below another debig output
I am using a GSM gateway with 2 SIM card from 2 different operator, so there is no trunk ISP main number
I used one number of the 2 sim card as trunk ISP number
Please help
004781: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.1.1:5060 SIP/2.0
Max-Forwards: 70
Via: SIP/2.0/UDP 192.168.1.3:5060;branch=z9hG4bK-242011176-CX04
From: <67893567>;tag=7C1EB3001750-13201430167893567>
To: <67893567>67893567>
Call-ID: 7C1EB3001750-10022159@192.168.1.3
CSeq: 27 REGISTER
Expires: 600
Content-Length: 0
004782: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 16 Oct 2010 10:24:57 GMT
CSeq: 27 REGISTER
Content-Length: 0
004783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 423 Interval Too Brief
To: <67893567>;tag=2CDDE31C-20B67893567>
CSeq: 27 REGISTER
Min-Expires: 3600
Content-Length: 0
004784: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:192.168.1.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK10E91964
Date: Sat, 16 Oct 2010 10:25:22 GMT
Call-ID: 96046F4C-D7B711DF-977CEFB4-7D00ADBA
Max-Forwards: 70
Timestamp: 1287224722
CSeq: 343 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
004785: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
004786: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: end of list
004787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 343 REGISTER
10-17-2010 05:22 AM
Either way, you need to reach out to the device responding to the REGISTER message to find out what they don't like about the formatting, and why they respond with a 5xx.
