Warning message
mirober2 Sat, 10/09/2010 - 10:30
  • Cisco Employee,
Hi Samuel,
The 3560 doesn't have a password configured on it by default. You may want to double check the procedure for accessing Express Setup in case a step was missed:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/hardware/quick/guide/3560gsg_08.html#wp49930
If that still doesn't work, you can reset the switch to factory defaults by following this guide:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/hardware/quick/guide/3560gsg_08.html#wp46478
Hope that helps.
-Mike
