Warning message
UnityConn forward message add address option
Oct 8th, 2010
I have a customer that forwards alot of emails to various UConn subscribers but does not like the fact that he has to dial 91 every time he wants to add another address.  I looked all over the keymapping field to see if I can change that but cant find the option.
Ex.  User checks messages and presses 5 to forward.  User adds a pre-message then presses #.  spells by name or number, adds the first address then is prompted to dial 91 to add additional addresses or press # to send.
We want to change the 91 option to a something else.  Can this be changed and if so, where is the option?
Thanks.
Rob Huffman Fri, 10/08/2010 - 08:59
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Edward,
Go to the User > Edit> Send message Settings > "Check" Continue Adding names after each Recipient
This will remove the 9-1 option after each name/extension is entered
Cheers!
Rob
