10-13-2010 06:29 AM
Hello, I have a question which is driving my insane I have a IPSEC VPN from a 5505 device connecting to HeadOffice. On the ASA5505 I need to know how I can set the local id to a IP address of my choice. ASA5505===DHCP====Router===PublicIP=======Internet======PublicIP==HeadOfficeVPN The Headoffice IPSEC is set to connect to my public IP + PSK The problem is that my ASA5505 is behind a router so my local id presented to the VPN is currently not my public IP. As a result the VPN tunnel will not establish and errors with Invalid ID Info ( 18 ) , Invalid Message ID ( 9 ) I need to work out how to set the LocalID of the ASA unit to my PublicIP address e.g 85.190.142.68 I normally use Billion Routers and they simply have a field for me to set the Local ID which would normally be the WAN IP address but when stuck behind a NAT then I am able to enter the public IP directly. I simply cannot find the same setting on the ASA unit. Any insight appreciated. Thanks |
10-13-2010 06:57 AM
Tahir,
If you're talking identity as in what is being exchnaged in main mode message 5 and 6.
bsns-asa5520-10(config)# crypto isakmp identity ?
configure mode commands/options:
address Use the IP address of the interface for the identity
auto Identity automatically determined by the connection type: IP
address for preshared key and Cert DN for Cert based connections
hostname Use the hostname of the router for the identity
key-id Use the specified key-id for the identity
If ASA does use IP address it will use address assigned to interface to which crypto map is attached.
Why not do ezvpn or identity based on hostname?
Marcin
10-13-2010 08:02 AM
Thank you for your quick response.
I cannot use ezvpn because the HeadOffice Side is not in my control and is also not cisco (Astaro)
The problem as I can identify is to do with DHCP / NAT at my end.
HeadOffice have given me vpn access with a PSK + fixed to my static IP address e.g 81.112.208.125
If I do the setup as:
192.168.210.0/24----ASA5505VPN-----81.112.208.125-----Internet-----88.193.146.66--------HeadOfficeVPN--192.168.130.0/24
Then my setup works fine as there is no nat
I can set the outside interface with the IP of 81.112.208.125
When I setup a IPSEC VPN it connects first time with no problems.
However if I stick a router in fron of my ASA5505 then the trouble starts:
e.g
192.168.210.0/24---ASA5505VPN---192.168.0.103--Router--81.112.208.125---Internet---88.193.146.66----HeadOfficeVPN
So my side is NATed
In this scenario I get: (extract)
6 Group = 88.193.146.66, IP = 88.193.146.66, Automatic NAT Detection Status: Remote end is NOT behind a NAT device This end IS behind a NAT device
5 Group = 88.193.146.66, IP = 88.193.146.66, Received non-routine Notify message: Invalid ID info (18)
5 Group = 88.193.146.66, IP = 88.193.146.66, Received non-routine Notify message: Invalid message id (9)
As far as I can see the issue is that the id for the 5505VPN is now 192.168.0.103 and not 81.112.208.125
I use to have a similar problem on my Billion Router but solved it by Setting Local ID to IP Address 81.112.208.125
I assume I have to do something similar on the ASA5505 unit but am lost as to exactly what and where
Would configure mode commands/options be the correct fix here and if so how would I use it?
10-13-2010 08:49 AM
Tahir,
According to the best of my knowledge neither ASA nor IOS will do that sort of spoofing.
It's an odd reason to drop and certainly not one that we do on our devices unless PSK is missing.
Can you get fill "deb crypto isakmp 255" when the ASA is trying to initiate?
Marcin
10-13-2010 09:21 AM
Hi Marcin,
It is strange as I would have thought that this was a simple NAT issue.
From what I can work out the HeadOffice Side Tunnel has been set to initate a tunnel with:
e.g 81.112.208.125 and PSK 1234
As the ASA5505 is stuck behind the router and presents its outside interface as 192.168.0.103
then the tunnel will not establish.
If I move the ASA5505 towards the Public WAN so that its outside interface is 81.112.208.125
then everything is good.
The really annoying thing is that the Billion has no problems with this at all!!!
Am I on the right track in identifying the issue or is there something else at fault?
I cannot do this via the ASDM and assume I need to do it telenet via the console cable
which I do not have here.
10-13-2010 10:05 AM
Tahir,
During mainmode messages 1-4 we don't exchange IP address.
You only exchange VIDs
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftipsnat.html
"During Internet Key Exchange (IKE) phase 1 negotiation, two types of NAT detection occur before IKE Quick Mode begins—NAT support and NAT existence along the network path.
To detect NAT support, you should exchange the vendor identification (ID) string with the remote peer. During Main Mode (MM) 1 and MM 2 of IKE phase 1, the remote peer sends a vendor ID string payload to its peer to indicate that this version supports NAT traversal. Thereafter, NAT existence along the network path can be determined".
The problem is that the other side might not recognize properly some VID?
Anyway if NAT is detected we should start using NAT-T and again should not be problem from Cisco's side.
The only problem I could see if when IKE peers exchange MM5 and MM6 messages. If ASA is set to send identity as IP address it will most likely send the IP address assigned to interface we have crypto map on.
Are you sure you have nat-t enabled on ASA?
Marcin
10-13-2010 12:13 PM
Fair Question
*As far as I am aware NAT-T is enabled of ASA unless you disable it.
*I ran crypto isakmp nat-traversal 20 just in case but no joy
*On a Test VPN Tunnel Setup By HeadOffice where they set it to Respond Only and therefore did not fix the Branch End Public IP the IPSECVPN worked fine behind the router. Therefore NAT-T I think is doing its job.
I think this is the root of the problem and unless we can tell it to send an alternative ID, then I am stuck with using the Billion.
Anyway I attach the relevent extracts in case I have missed something obvious
Group = 88.193.146.66, IP = 88.193.146.66, PHASE 1 COMPLETED
Group = 88.193.146.66, IP = 88.193.146.66, De-queuing KEY-ACQUIRE messages that were left pending.
Teardown UDP connection 83 for outside:192.168.212.11/161 to inside:192.168.210.30/1030 duration 0:02:17 bytes 312
Teardown dynamic UDP translation from inside:192.168.210.30/1044 to outside:192.168.0.103/25949 duration 0:00:30
Teardown dynamic UDP translation from inside:192.168.210.30/1030 to outside:192.168.0.103/6834 duration 0:02:30
Group = 88.193.146.66, IP = 88.193.146.66, QM FSM error (P2 struct &0xd8635630, mess id 0xfff3c84b)!
Group = 88.193.146.66, IP = 88.193.146.66, Removing peer from correlator table failed, no match!
Group = 88.193.146.66, IP = 88.193.146.66, Session is being torn down. Reason: Lost Service
Group = 88.193.146.66, Username = 88.193.146.66, IP = 88.193.146.66, Session disconnected. Session Type: IKE, Duration: 0h:00m:32s, Bytes xmt: 0, Bytes rcv: 0, Reason: Lost Service
IP = 88.193.146.66, Received encrypted packet with no matching SA, dropping
Thank you again for all your help!
10-13-2010 01:00 PM
Tahir,
Phase 1 is completed! So we might as well forget about VIDs and identity exchange.
I did a quick check on our case DB.
I found several mentions of this log message, every time this is related to PFS settings.
ASA uses group 2 if PFS set.
Some other cases where problem was a misconfiguration of ACLs.
It would not explain why moving device directly to public IP would make things work.
Marcin
10-13-2010 01:43 PM
Hi Marcin,
Thank you again for the quick response.
I am pretty sure PFS is not inolved.
At the HeadOffice the settings are:
IKE: AES 256 MD5 28800 Group 5 MODP 1536
IPSEC: AES 256 MD5 3600 PFS:None
At my end on the ASA5505 the settings are:
Result of the command: "show run crypto ipsec"
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
Result of the command: "show run crypto isakmp"
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash md5
group 5
lifetime 86400
Result of the command: "show run crypto map"
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 88.193.146.66
crypto map outside_map 1 set transform-set ESP-AES-256-MD5
crypto map outside_map interface outside
So as you can see PFS is disabled on both ends.
In Summary:
Billion S10 Security Device Connects VPN No Problems from behind router and getting its address via DHCP from router as long as I set VPN ID to my Public IP Address 81.112.208.125
ASA5505 No Problems if connected directly to Public IP 81.112.208.125 with above settings
ASA5505 Problem if behind router and getting its outside address via DHCP from router.
10-13-2010 01:46 PM
Tahir,
Well I'd suggest to open a TAC case with both our TAC and whoever is handling the headend device.
It would be interesting to:
1) Know why they reply with invalid ID
2) How the whole debug looks both sides.
Knowing one can maybe explain the other, but having both is being able to get this to work ;-)
Marcin
10-13-2010 02:18 PM
Hi Marcin,
I think I will have a further play first and as you suggest examine both ends for a more complete picture as to what is happening.
It is not a critical issue as I can still revert back to the Billion or move the ASA unit to Public WAN.
At first I thought it would be a simple command to set the local ID hence my post, but clearly this is not the case!
If after examination of logs on both ends during the weekend, I discover anything new then I will post back here
and obviously also if I do get a solution!
Thanks again for all your advice.
10-13-2010 04:17 PM
Tahir,
As I said it would be interesting to know what's happening on the headend, as you see this is not a typical message ASA is expecting - thus it cannot react in a way the other side expects.
If possible debugs on both ends would be helpful.
ASA has type isakmp captures - with them you can have a look into IKE packets.
capture IKE type isakmp pack 1512 ....
Marcin
