Warning message
CCM upgrade: from 4.2(1) to 4.2(3)
Answered Question
Oct 13th, 2010
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hello guys,
I have installed CCM version 4.2(1) but now I need to upgrade it to 4.2(3). I tried to install a patch 4.2(3)sr4a and an error pops up: Call Manager not 4.2(3). This patch is for version 4.2(3). (something like that). Any ideas? Is it possible to do this kind of upgrade?
Thank you very much!
Wilson
Correct Answer by David Hailey about 6 years 10 months ago
On 4.x, you have to install the base SW version before you can apply patches.  The patches are just that - patches.  So, you'll need to upgrade to 4.2(3) base and then you can go from there.
Check the following link:  http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/4_2_3/upg423.html
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Wed, 10/13/2010 - 13:54
  • Purple, 4500 points or more
Hailey
wilsonsant Fri, 10/15/2010 - 12:25
Hi David,
Thank You for help. The document was very usefull.
Wilson
