Warning message
question about 'lighting' fiber strands?
Answered Question
Oct 13th, 2010
Hello all. I am new to fiber optic networks and have a question in regards to
a comment at work. At work we have multimode fiber connecting
our campuses and the gig link is getting saturated. A coworker informed me that they have 2 spare dark fiber strands available and that we can light up those 2 strands and form an etherchannel bundle to increase bandwidth.
My question is what does he mean by light up those 2 fiber strands and how can this be accomplished. They have 6509 core switches on both campuses and the campuses are about 500 meters apart. Thanks. I really do not have much more detail than this at this time, I am just trying to understand the concept.
note - I understand etherchannel part and what he is trying to accomplish with it, I just dont know what he intends to do to 'light' the fiber.
Correct Answer by Tom Randstrom about 6 years 10 months ago
Select the proper type of Optical Transceiver Module (SFP/GBIC) to install in the transceiver module slot of the 6509 line card, per the below compatibility chart.  In your case, you will probably just match the model number of the current transceivers modules currently running on the other fibers.
Transceiver Compatibility Chart - Gigabit Ethernet
<http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp139518>
Then, you select the transceiver model based upon the type of fiber you will be using (multimode, 50 or 62.5 micron core, OM-?) and the links length.  The data sheets for the transceivers will give you the supported link distances.
Transceiver Data Sheets
<http://www.cisco.com/en/US/products/hw/modules/ps5455/prod_module_series_home.html>
Make sure to clean all the connectors before inserting them into the transceiver modules.
Hope this helps!
Overall Rating: 5 (1 ratings)
Leo Laohoo Wed, 10/13/2010 - 21:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Plug a fibre optic module and cable on one end and repeat on the other end and then you can "light-em-up".
Correct Answer
Tom Randstrom Thu, 10/14/2010 - 05:47
  • Gold, 750 points or more
Hope this helps!
