Failure login "IP Phone Agent" service
Oct 15th, 2010
Hi! I have an issue. When I try log in the IP Phone Agent service I get an error: "selected service IP Phone Agent isn't active. Select another service IP Phone Agent".
The service URL seems correct: http://ip_address_UCCX_server:6293/ipphone/jsp/sciphonexml/IPAgentInitial.jsp and the Cisco Browser and IP Phone Agent Service is started and has a status "IN_SERVICE".
What is the problem here?
We use UCCX Premium 7.0(1) and CUCM 7.1.5
Thanks in advance!
Ruslan
Overall Rating: 5 (1 ratings)
anubhati Fri, 10/15/2010 - 06:42
  • Cisco Employee,
Go through the tech tip below and confirm the configuration. If every thing seems to be good then it might be a issue with the CTI manager service on CUCM and you will have to restart that service.
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/products_tech_note09186a008029e6d5.shtml
Following is the order  to follow to restart the CTI service
a) In CUCM cluster first stop CTI service on all subscribers
b) restart the service on publisher
c) Then start it on all subscribers.
After the CUCM CTI service is up on CUCM cluster  restart the IPPA service in UCCX
hope this helps
Anuj
Ruslan Kravets Fri, 10/15/2010 - 08:12
I checked everything: service parameters, URL. And I restarted CTI manager service and IPPA service with the algorithm which You had described. I tried to create a new service with these settings but nothing helps. I have the same error. Any ideas else?
Thank You!
Ruslan
anubhati Fri, 10/15/2010 - 08:53
  • Cisco Employee,
If UCCX on 7.0(1) Sr5 ?
Anuj
Ruslan Kravets Sun, 10/17/2010 - 22:34
Yes, that is 7.0(1)SR05_Build504. We recently upgraded UCCX from the 7.0 version and I suspect that the problem occurred after that.
Ruslan
Jerry Cody Fri, 10/15/2010 - 13:40
  • Cisco Employee,
Increase the timeout:
Please perform the following:
1.    Open Regedit on the UCCX server
2.    Navigate to the following string  HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc. \CRS \Properties\application.MIVR.properties
3.    Select “com.cisco.user.io.timeout”
4.    Right-click, choose Modify and then enter 30000.
5.    File, Exit and close Regedit.
Please also ensure that in AppAdmin, under System> Cisco Unified CM Configuration  that the CUCM primary IP is set as the first AXL Service provider. If it is not, you can modify the order, then Update that.
Ruslan Kravets Sun, 10/17/2010 - 22:51
Thanks for reply! The value of "com.cisco.user.io.timeout" already is 30000. And CUCM primary IP has already set as the first AXL Service provider
Ruslan
Kris Lambrechts Tue, 10/19/2010 - 12:10
  • Cisco Employee,
I'm just going on my experience with IP Phone Agent on Enterprise Contact Centers, but I'm guessing it would work the same on UCCX. Basically IPPA is working in an Active-Standby architecture, so if you have a High Availablity node the service is currently Active on the Standby node.At least on Enterprise, it would give you that message when the other side is Active. The upgrade probably triggered it to fail-over.
Do you have a service configured on your phones pointing to the same URL on the 2nd node ? Give that a try.
To make it go back to your Primary node, you'll want to log on to the Standby node and restart the IP Phone Agent service or possibly the License and Resource Manager to have it fail-over back to the Primary (don't do it during business hours).
Allan Perocho Thu, 10/21/2010 - 09:51
Is the IP Phone Agent now working in active-standby mode in UCCX 7? In lower version, you need to create 2 IP Phone Agent Service in the CallManager, one pointing to the Primary and second to the Secondary. Then you need to add this in the device subscription.
Ruslan Kravets Fri, 10/29/2010 - 04:52
Hi, there!
Yes, we use high-availability mode. I tried to change an address in the URL to the address of secondary node and also a tried to restart IPPA service in the both nodes but it didn't help. Then I restarted the secondary server and the service became up. It's strange because the address in the service URL is set to ip of primary server...
Thanks for Your replies!
W S H FERNANDO Thu, 04/10/2014 - 01:45
Hi Ruslan
I got the same problem, issue is your pointed UCCX Server is not the master Server. As I know Cisco IP Phone Agent is not supporting automatic fail-over, so Agent need to manually point to Master UCCX server to gain this IP Phone service. I have done some workaround, I created two services pointing to both UCCX servers and Assigned both services with Agent Phone, so if the Agent getting this message, agent can select other service.
Regds
Sasith
