Warning message
Renew certificate CSS 11501
Answered Question
Oct 15th, 2010
I have a CSS 11501 running 08.10.1.06.  Is there a way to renew the existing SSL certificate on the box or must I create a new one?  All the doc I've read basically treats renewing the same as creating a new cert.  Thanks for your help.
Correct Answer by Daniel Arrondo Ostiz about 6 years 10 months ago
In the world of SSL certificates the concept of renewing doesn't exist. You always need to create a new certificate and import it to replace the old one.
To generate this new certificate, you can either use the old private key or create a new one. If you use a new one, then, make sure to also import it along with the new certificate.
Overall Rating: 5 (1 ratings)
Correct Answer
Daniel Arrondo Ostiz Fri, 10/15/2010 - 07:39
  • Cisco Employee,
