10-15-2010 01:26 PM - edited 03-06-2019 01:33 PM
cisco configuration professional (ccp) uses https and
ssh ports to connect
it is easy to change the htttp port or https port on the router
but how to change the ssh port
if you give the command:
ip ssh port 8083 rotary 1
nothing changes in ccp it stays the same
jilles
10-16-2010 09:36 AM
To change the ssh port on the router apart from entering 'ip ssh port 8083 rotary 1', you need to assign the VTY lines to 'rotary 1'. For example.
line vty 0 4
rotary 1
Shankar
10-16-2010 03:19 PM
i want the port ssh chnaged for the lan acces not the serial acces.
jilles
10-18-2010 08:09 AM
If you are looking to change the SSH port using CCP, then go to manage devices in CCP. Expand the drop down option box for your router, click on connect safely. You will get the option to enter the port numbers for HTTPS and SSH here. Please let me know if this is what you are trying to achieve. Also let me know the CCP version number that you are running.
Shankar
10-18-2010 09:12 AM
i know, but thatthe lan
ssh port on the router side should als be changed if you change it in ccp, your code does that ?
jilles
10-18-2010 05:22 PM
Well, do the changes in CCP and please enter the following in the router as I had mentioned:
line vty 0 4
rotary 1
transport input ssh
VTY lines are for telnet or SSH. Console is the serial line. VTY lines are through network interfaces (be it ethernet or any other interface).
- Shankar
11-02-2010 08:50 AM
I always follow this up with an ACL blocking 22.
line vty 0 4 |
access-class TelSSH in |
permit tcp 192.168.0.0 0.0.0.255 any eq 8083 log |
deny ip any any log |
10-04-2016 02:10 AM
Hi guys here is a great video for changing ssh on router
https://www.youtube.com/watch?v=9Dqcp7zS7zg
it explain many stuff on how to change ssh and rotary settings .
