Warning message
Nicolas Darchis Tue, 10/19/2010 - 12:38
  • Cisco Employee,
Can you console to the ap with a console cable ? That would help a lot !
Nicolas
ruth_kohler Tue, 10/19/2010 - 13:55
OK, figured it out. Guess I was brain dead.  I read it as just the Power Injector needed to be connected......but amazing, once you connect the actual 1310 - it all works fine!
srosenthal Mon, 10/25/2010 - 19:11
You are correct.  The power injector is just that and the bridge unit actually has all the intelligence in it.    The power injector is just your interface connection to the unit for console and ethernet and provides power to the bridge.
Seth
