CSA 6.01 MC change IP address
Oct 19th, 2010
just some short questions about CSA-MC v6.01 and changing IP address of it.
Is it possible to change (only) IP address of the CSA-MC without interfering CSA agents ?
If so, is there a process/guide what steps to do ?
Thx in advance
Stefan
tsteger1 Wed, 10/20/2010 - 10:40
  • Red, 2250 points or more
It should not present a problem to change the MC address and DNS record unless your hosts resolve to an IP address instead of a FQDN.
In that case, you'll need to do something else.
Tom
STEFAN KLUEPPEL Sun, 10/24/2010 - 05:22
Hi Tom,
well, just changing the IP should not be an issue from logical point of view. But
I heard about problems with agents still using the old MC IP
after changing the IP and asking therefore
getting documents (there should be one) for the process
of changing IP (and if necessary later additionally hostname).
regards
Stefan
Related Content
