Warning message
Chad Peterson Tue, 10/19/2010 - 14:04
  • Cisco Employee,
Because your supervisors are different you will need to remove both supervisors and replace them at the same time.  You won't be able to run a SUP32 and a SUP720 at the same time.
Jeremy Waldrop Tue, 10/19/2010 - 14:11
  • Silver, 250 points or more
Thank you for the quick reply Chad, I guess we will have to back up the current config, replace the modules and then restore the config?
