10-19-2010 04:42 PM - edited 03-01-2019 02:21 PM
Hello gurus:
i need help on one SCA BB 3.5.5 error i am getting this error and i cannot open any .pqb file and i cannot log into he boxes
Could not create the view: Plug-in site.xml.editor was unable to load class com.cisco.scasbb.client.ui.netnav.site_xml.presentation.NetNavView.
any recomendation?
steps i made:
re instaling the software doesnt work.
comunication from PC to SCE is OK. i can telnet to SCE but cannot open console for any device SCE i have i am usin SCE 2020
Solved! Go to Solution.
10-20-2010 07:01 AM
If re-installing doesn't work, you can try the following.
1. Uninstall
2. Delete the directories
x:\Documents and Settings\
3. Reinstall
Tom
10-19-2010 09:08 PM
Hi Fernando,
Hasically something went horribly wrong with the SCABB console. Are you trying to install it on a new PC ?
Can you paste the output of the logs from help > Configuration Details > View Details.
~Upi
10-20-2010 07:01 AM
1. Uninstall
3. Reinstall
Tom
10-20-2010 10:56 AM
Thanks a lot Gurus!!! now i can use SCA BB console following steps by Tom Debruyne
by the way i lost all mine last hosts configured there but no problem i can add them now!
Thanks Tom!!!
