Warning message
BGP Received Prefix from Peer
Oct 20th, 2010
Hi All,
Is there a way to know how many prefix a certain peer advertises to my router even though the soft-reconfiguration inbound is not configured in bgp? We disabled soft reconfiguration because it consumes a lot of CPU.
ISP-RTR#sho ip bgp neighbors 10.1.1.2 received-routes
% Inbound soft reconfiguration not enabled on 10.1.1.2
Overall Rating: 5 (1 ratings)
njangale Wed, 10/20/2010 - 04:27
sh ip bgp summary will list  the details fo the neighbors and the last column lists you the prefixes learned from each neigbor.Another thing you see is the sh proc cpu history | include BGP will help you find if BGP is consuming CPU or not.
BubbleGang Wed, 10/20/2010 - 05:07
Ok njangale im confused. Before when the soft reconfiguration was in place and i issue the show ip bgp neig received-routes command it show that we are receiving 300000+ prefixes from our ISP. But the number of prefix received does not match when i issue the show ip bgp summary command.
ISP1>sho ip bgp neighbors 10.1.1.1 received-routes
% Inbound soft reconfiguration not enabled on 10.1.1.1
Note: It showed 300000+ prefix
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.1.1.1     4  3356 13409542  227379    41232    0    0 22w3d        1158
