Warning message
NAC NAM/NAS SSL Certificate Installation
Oct 21st, 2010
Recently installed NAC and requested certificates from our CA.  We received the certificates and when I attempt to install them on the servers using the web interfaces for the NAM/NAS I am given an error stating "No matching end-entity certificate/private key were found ..."...so...I thought perhaps I have to install the private key which was generated separately...tried to import private key but I get an error there as well...there really isn't much on this in the manual...how do I install this certificate I received from my CA?....
Thanks for your assistance.
Liam
Faisal Sehbai Thu, 10/21/2010 - 12:53
  • Gold, 750 points or more
Liam,
Depends on the version, but in later codes you have to combine the key and certificate in one file and upload that.
Take a look at some of the documents also posted here about certificates. They will give you the insight you're looking for:
https://supportforums.cisco.com/community/netpro/security/others?view=documents
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Related Content
