Problem in configuring port-channel between nexus and 3760 switch
Oct 22nd, 2010
i am facing problem in bring up the port-channel between the nexus 7k series swich and cisco 3760 L3 switch.
does this possible at the first place and of possiable what could be the problem that shoping then to come up
Logesh
It could be a protocol mismatch/negotiation error or you have them in a state that will not bring the channel up, or you are not using the correct ports or an incorrect cable/speed/duplex/mdix issue.
Best test is
interface x/x
channel-group # mode on
On both sides, if it comes up cool - if not, then you need to check the cable/ports.
